What is Wattmeter?
A wattmeter is a device that measures the amount of electricity delivered to or generated by an electrical circuit. These instruments are frequently employed for the distribution and transmission of electric power, as well as for protection.
Wattmeter
WATTMETER
A wattmeter typically consists of two coils:
  • Current coil and
  • Potential coil
What is Current Coil?
A coil, such as a wire wound around an electrical conductor, is essentially what a current coil is. Typically, a soft iron core acts as the conductor while insulated copper wire acts as the coil. It has been noted that the coil start functioning like a magnet when the conductor’s coil is carrying current.
What is Potential Coil?
Potential coil refers to a coil or winding linked in shunt across a circuit (such as in a wattmeter). In order to carry a current that is proportionate to the supply voltage, a potential coil is attached across the supply line.
What is the SI Unit of Wattmeter?
Watt is the SI unit for electrical power.
Symbol of Wattmeter:
A circle on the capital letter W can be used to represent a wattmeter.
Symbol Of Wattmeter
SYMBOL OF WATTMETER
How Wattmeter Works?
Voltage (V), current (A), power (W), power factor (pf), and energy consumption can all be measured with a conventional wattmeter (kWh). The range of measurement accuracy varies from 1% to 5% depending on the device’s brand and type. A wattmeter with a 2% measurement error can display a power of 100 W as 98 W, 102 W, or even 98 W. The equipment is measuring this ratio as it becomes down.
A lot of current can harm the wattmeter, which is a complicated instrument. All wattmeter is designed to handle a safe maximum current. The maximum permitted current in many devices is restricted to 16 A. It denotes a power output of 3,680 W at 230 V AC mains voltage.
It is important to keep this current and power value in consideration to avoid harming the wattmeter. Some gadgets also include overload protection.
Components Of Wattmeter
COMPONENTS OF WATTMETER
It wouldn’t be inaccurate to imply that the wattmeter uses some energy as well. The typical power usage of a wattmeter is less than 0.5 W.
Thousands of times per second, the digital wattmeter measures the circuit’s current and voltage. With the aid of the internal computer, it multiplies the current and voltage to determine the electrical power.
Additionally, this processor is capable of recording data on lowest voltage, highest voltage, lowest power, and greatest power. It is possible to monitor the microprocessor, voltage changes, and power line interruptions.
How to use a wattmeter ?
  1. Ensure that the wattmeter is suitable for the type of circuit (AC or DC) and the power range you are measuring. Check that the wattmeter is in good working condition.
  2. Before connecting the wattmeter, turn off the power to the circuit to avoid any electrical hazards. Use appropriate personal protective equipment (PPE) if necessary.
  3. For Handheld Wattmeters: Plug the wattmeter into an electrical outlet or power source. Then, plug the device you want to measure into the wattmeter’s outlet.
  4. For Installed Wattmeters: Connect the wattmeter in series with the load or power source. Ensure that the connections are secure and correct according to the wattmeter’s manual.
  5. If the wattmeter has multiple ranges or scales, select the appropriate range that matches the expected power level to ensure accurate measurements.
  6. Restore power to the circuit. The wattmeter will begin measuring and displaying the power consumption or generation.
  7. Observe the wattmeter’s display to read the power measurement. For digital wattmeters, the reading will be shown on an LCD screen. For analog wattmeters, read the value from the dial or pointer.
  8. Use the data to assess the power consumption, efficiency, or performance of the device or system being measured. This information can help in making adjustments or improvements.
  9. After taking the measurements, turn off the power to the circuit before disconnecting the wattmeter.
  10. Safely unplug the wattmeter from the circuit or power source.
  11. Document the measurements and review them for analysis or reporting purposes. and regularly calibrate and maintain the wattmeter as per the manufacturer’s instructions to ensure continued accuracy and reliability.
The wattmeter is utilised in a variety of settings, including
  • Laboratories,
  • Industries, and
  • Power distribution and transmission measurements.
Watt and Volt:
The formula for the correlation between watt and volt is:
Where,
  • Power is measured in watts.
  • Electric potential is measured in volts.
  • Current is measured in amperes.
The potential difference between two terminals of a conducting wire is measured in volts.
When a current of one ampere travels over a potential difference of one volt, the rate at which electrical work is produced is measured in watts.
A proportionate correlation was established between watt and volt. In other words, watt and volt are precisely proportionate. Which suggests that
  • The electric potential in terms of volts increases as electric power in terms of watts increases, maintaining a constant electric current.
  • Electric potential, measured in volts, decreases together with decreasing wattage, keeping electric current constant.
Formula for Wattmeter:
The various electric circuits’ power is measured by wattmeter. It requires a power formula to work.
Wattmeter Reading Calculation
WATTMETER READING CALCULATION
Types of Wattmeter:
Following are two different types of wattmeter:
  • Induction Type Wattmeter and
  • Dynamometer Type Wattmeter
  • Digital watt meter
  • Shunt Magnet and
  • Series Magnet
are the two laminated electromagnets that make up the induction wattmeter. The supply is connected across the shunt magnet, which conducts a current inversely proportional to the supplied voltage. The shunt magnet’s coil is designed to be very inductive, causing the current to lag the supply voltage by 90 degrees.
INDUCTION TYPE WATTMETER
The operational field of a dynamo-type wattmeter, which uses moving coils, is created by a fixed coil elsewhere. A fixed coil with two equal parts that are parallel to one another makes up these instruments. To prevent hysteresis losses, these two fixed coils must operate together. The pointer is connected to the moving coil by a spring and begins to move when the moving coils begin to move as a result of an alternating current flowing through the fixed coil, which creates a magnetic field.
DYNAMOMETER TYPE WATTMETER
Digital Wattmeter
A modern digital wattmeter samples voltage and current thousands of times per second. For each sample, it multiplies the voltage by the current at that exact moment. The average of these products over at least one cycle gives the real power. The real power divided by the apparent volt-amperes (VA) determines the power factor. A computer circuit processes these sampled values to calculate RMS voltage, RMS current, VA, power (watts), power factor, and kilowatt-hours. These readings can be displayed on the device, stored to create a log and calculate averages, or transmitted to other equipment for further use. The accuracy of wattmeters in calculating energy consumption can vary significantly, especially when the real power is much lower than the VA, such as with highly reactive loads like electric motors. Simple meters may only be calibrated for sinusoidal waveforms, leading to potential errors when measuring waveforms that deviate significantly from sinusoidal, such as those produced by switched-mode power supplies used in much electronic equipment. These errors might not be specified in the meter’s manual.
Watthour Meters
A watthour meter, often referred to as an electricity meter, is an instrument that measures electrical energy in watt-hours by integrating power over time—essentially multiplying the power by the elapsed time. Modern digital electronic meters measure a wide range of parameters, making them versatile tools that can also function as wattmeters. These parameters include voltage, current in amperes, apparent instantaneous power, actual power, power factor, and energy consumption in kilowatt-hours (kWh) over a given period. Additionally, they can calculate the cost of electricity consumed.
  • Wattmeters display the electric power consumed by devices, providing real-time data on energy usage.
  • They monitor power consumption, allowing users to track and manage energy use effectively.
  • Wattmeters can measure voltage, current, power, power factor, and energy consumption, typically with an accuracy ranging from 1% to 5%.
  • They can be damaged by excessive current, so proper handling and rating adherence are important.
  • While wattmeters do consume a small amount of energy themselves, this consumption is minimal.
  • Both analog electric and modern digital wattmeters are available in the market, catering to various needs and preferences.
  • Electric companies use wattmeters to record the amount of electricity and energy consumed by their customers.
  • Wattmeters are commonly used to measure the power output of small-scale photovoltaic (solar) arrays, helping determine the electrical energy generated by the system.
  • They measure the power generated by renewable energy systems, such as solar panels or wind turbines, assisting in properly sizing the system.
  • Wattmeters have broad applications in laboratories and industries, particularly for measuring transmission or distributed power.
  • Wattmeters are often used to measure the power output of motors, aiding in assessing their functionality and determining if they need to be replaced.
  • They monitor the power used by electrical equipment, ensuring it is being used efficiently and correctly.
  • Wattmeters are used to track power consumption of electrical appliances, helping consumers optimize their electricity usage and reduce energy waste
The primary function of a wattmeter is to measure electrical power in watts. It can measure both active power (real power) and reactive power in AC circuits, providing an immediate reading of the power consumed or generated by the connected load or source.
Wattmeters often feature multiple scales to accommodate a wide range of power levels. This allows users to measure both low and high power levels accurately. Some wattmeters have switchable scales or auto-ranging features that automatically adjust to the specific power levels.
Accuracy is a crucial property of wattmeters. High-quality wattmeters are designed to provide precise measurements under various conditions. Accuracy is typically specified as a percentage of the full-scale reading and varies depending on the type and class of the wattmeter.
Most wattmeters are designed for use in alternating current (AC) circuits, capable of measuring power in both single-phase and three-phase AC systems. They account for AC power characteristics, such as voltage phase shifts.
Wattmeters can be classified into two-element and three-element types. Two-element wattmeters measure only active power, while three-element wattmeters measure both active and reactive power. The three elements generally correspond to voltage, current, and a phase-shifting network for measuring power factor.
Wattmeters often include multiple measurement ranges to cover a broad spectrum of power levels. Switchable or selectable ranges enable accurate measurement of both low and high power levels, providing flexibility for various applications.
To enhance durability and maintain accuracy, many wattmeters are equipped with overload protection mechanisms. These safeguards prevent damage from unexpected voltage or current spikes that exceed the wattmeter’s designed capacity.
Wattmeters may feature either digital or analog displays. Digital wattmeters provide precise numerical readings, while analog wattmeters use a needle or pointer to indicate power levels on a scale. The choice between digital and analog depends on user preference and application requirements.
In some applications, wattmeters are integrated into broader measurement and control systems. This integration allows for remote monitoring, data logging, and automation of power measurements. Communication interfaces such as RS-485 or Ethernet may be included for connectivity.
Wattmeters come in various form factors, including handheld devices for field measurements or benchtop models for laboratory settings. Portability and ease of use are important considerations, especially in scenarios where measurements are needed at different locations within a facility
  • Provides precise measurement of electric energy, aiding in effective electricity management.
  • Delivers immediate data for quick adjustments to electricity usage.
  • Capable of measuring both active and reactive power, suitable for various applications.
  • Helps identify energy issues, enabling targeted improvements.
  • Assists users in reducing energy waste by providing insights into consumption patterns.
  • High-quality wattmeters can be expensive.
  • May require technical expertise for setup, especially in large systems.
  • Needs regular calibration and maintenance to maintain accuracy.
  • Analog models may have lower resolution compared to digital ones.
  • Requires a stable power supply, which can affect performance during outages or fluctuations.
Application of Wattmeter:
  1. The wattmeter is widely used for measuring and debugging electrical circuits.
  2. The wattmeter is crucial for measuring the amount of power being distributed and transmitted.
  3. Utility frequencies are measured using an electromagnetic wattmeter.
  4. They are also utilized in the software industry to assess the power capacity and energy usage of electrical items.
  5. They are used to gauge the power rating of appliances like refrigerators, electric heaters, and other machinery.
  6. For particular objectives, these wattmeter are employed in a variety of laboratories.
There are two types of wattmeters: Analog wattmeters, which use dials to measure wattage, and digital wattmeters, which display the measured wattage on an LCD screen.
A wattmeter measures the power (in watts) used by a circuit by calculating the product of current and voltage. Watts is a unit of power, representing the rate of energy consumption.
Wattmeters can be connected in two ways. Handheld wattmeters are plugged into an outlet, with the device being tested plugged into the wattmeter. In buildings and homes, wattmeters are installed at the power grid access to measure total electricity usage.
Using a Wattmeter: Connect the wattmeter in series with the load and read the power in watts directly from the display.
Using a Multimeter: Measure the voltage across the load and the current through it, then multiply them to calculate power:
Power (P)=Voltage (V)×Current (I)
A wattage meter is a device that measures and displays the power consumption of an electrical device or circuit in watts.
