Torr to Millibar (mBar) Pressure Unit Conversion Calculator
This calculator helps you quickly convert pressure values from Torr to Millibar (mBar), useful for a variety of industrial, scientific, and engineering applications.
The Torr is a unit of pressure based on an absolute scale, defined as 1/760th of an atmosphere (atm). It is commonly used in vacuum pressure measurements.
The Millibar (mBar) is a metric unit of pressure, widely used in meteorology, as well as in industrial applications like pneumatics and HVAC systems. 1 mBar is equal to 100 Pascals (Pa).
Suppose you have a pressure of 500 Torr.
To convert it to mBar:
500 × 1.33322 = 666.61 mBar
So, 500 Torr is equal to approximately 666.61 mBar.
TorrmBar
1 Torr1.33322 mBar
10 Torr13.3322 mBar
100 Torr133.322 mBar
500 Torr666.61 mBar
760 Torr1013.25 mBar
1000 Torr1333.22 mBar
  • Vacuum Systems: Convert Torr values to mBar for accurate measurements in vacuum pumps and systems.
  • Meteorology: Useful for converting pressure data in weather forecasting and atmospheric studies.
  • Industrial Applications: Ideal for converting vacuum and low-pressure measurements in processes such as refrigeration and HVAC.
This Torr to mBar conversion calculator is an essential tool for professionals in industries where precise pressure measurements are critical.
