Instrumentation – Power Generation quiz part 4
    0
    193
    Welcome to your Instrumentation - Power Generation quiz part 4
    Murray loop test can be used for location of
    Which of the following devices should be used for accurate measurement of low D.C. voltage?
    A voltage of about 200 V can be measured
    It is required to measure the true open circuit e.m.f. of a battery. The best device is
    A direct current can be measured by
    To measure a resistance with the help of a potentiometer it is
    A phase shifting transformer is used in conjunction with
    Basically, a potentiometer is a device for
     In order to achieve high accuracy, the slide wire of a potentiometer should be
    To measure an A. C. voltage by using an A.C. potentiometer, it is desirable that the supply for the potentiometer in taken
