Psi to Millibar (mBar) Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from pounds per square inch (psi) to millibars (mbar).
A millibar (symbol: mbar) is a unit of pressure commonly used in meteorology to describe atmospheric pressure. It is equal to one-thousandth of a bar, which is a metric unit of pressure.
Pressure in mbar = Pressure in psi × 68.9476
Suppose you have a pressure of 14.5038 psi.
To convert it to mbar:
14.5038×68.9476=1000 mbar
So, 14.5038 psi is equal to 1000 mbar.
Psi (pound-force per square inch)Millibar (mbar)
1 psi68.9476 mbar
5 psi344.738 mbar
10 psi689.476 mbar
50 psi3447.38 mbar
100 psi6894.76 mbar
500 psi34473.8 mbar
1000 psi68947.6 mbar
  • Engineering Applications: Convert pressures in automotive, hydraulic, and pneumatic systems.
  • Instrumentation: For converting gauge readings from imperial units to metric units.
This calculator is essential for professionals and engineers who need to convert between these two pressure units, ensuring accuracy in calculations and measurements.
