This calculator allows you to convert pressure values from converting pounds per square inch (psi) to kilograms per square centimeter (kg/cm²):
Definition: Pound-force per Square Inch (psi)
Definition: Kilogram per Square Centimeter (kg/cm²)
A kilogram per square centimeter (symbol: kg/cm²) is a unit of pressure where one kilogram-force is applied over an area of one square centimeter. This unit is commonly used in fields such as material science and engineering.
Formula for Psi to kg/cm² Conversion:
Pressure in kg/cm² = Pressure in psi × 0.07030696
How to Convert Psi to kg/cm²: Example Calculation
Suppose you have a pressure of 100 psi.
- To convert it to kg/cm²: 100 × 0.07030696 = 7.030696 kg/cm²
- So, 100 psi is equal to 7.030696 kg/cm².
Quick Reference Conversion Table for Psi to kg/cm²
Here’s a quick reference table for common psi values to kg/cm²:
| Psi (pound-force per square inch) | kg/cm² (kilogram per square centimeter) |
| 1 psi | 0.07030696 kg/cm² |
| 5 psi | 0.3515348 kg/cm² |
| 10 psi | 0.7030696 kg/cm² |
| 20 psi | 1.4061392 kg/cm² |
| 50 psi | 3.515348 kg/cm² |
| 100 psi | 7.030696 kg/cm² |
| 200 psi | 14.061392 kg/cm² |
| 500 psi | 35.15348 kg/cm² |
| 1000 psi | 70.30696 kg/cm² |
Use of Psi to kg/cm² Conversion Calculator:
- Engineering Applications: Convert pressures in automotive, hydraulic, and pneumatic systems.
- Instrumentation: For converting gauge readings from imperial units to metric units.
This calculator is useful for professionals and engineers who work with systems that require conversion between these two pressure units, ensuring accuracy in calculations and measurements.
