Pascal (Pa) to Inch of Mercury (inHg) Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from Pascal (Pa) to Inch of Mercury (inHg), a widely used unit in weather, aviation, and industrial pressure measurements.
The Pascal (Pa) is the SI unit of pressure, equivalent to one Newton per square meter. It is commonly used in scientific and industrial applications for measuring and standardizing pressure.
The Inch of Mercury (inHg) is a unit of pressure based on the height of a mercury column that a given pressure can support under standard gravity at 0°C. It is widely used in meteorology, aviation, and industrial systems.
Suppose you have a pressure of 10,000 Pa. To convert it to inHg:
10,000 Pa×0.0002953=2.953 inHg
So, 10,000 Pa is approximately equal to 2.953 inHg.
Pascal (Pa)Inch of Mercury (inHg)
1 Pa0.0002953 inHg
1000 Pa0.2953 inHg
5000 Pa1.4765 inHg
10,000 Pa2.953 inHg
50,000 Pa14.765 inHg
  • Weather and Barometric Studies: Convert atmospheric pressure from Pascals to inHg for use in meteorology.
  • Aviation: Helpful in pressure unit conversions for altimeters and cabin pressurization systems.
  • Industrial Applications: Standardizes pressure readings for process controls and calibration.
  • Scientific Research: Assists in converting pressure readings for experiments and reports.
This Pa to inHg conversion calculator is an essential tool for professionals in meteorology, aviation, scientific research, and industrial operations requiring precise pressure unit conversions.
