Millimeter of Water Column (mmWC) to Bar Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from millimeters of water column (mmWC) to bar, which is essential for various instrumentation, HVAC, and industrial applications.
A millimeter of water column (symbol: mmWC or mmH₂O) is a unit of pressure that represents the pressure exerted by a 1 mm high column of water at 4°C under standard gravity. It is often used in low-pressure systems such as HVAC, gas pressure measurements, and water treatment.
A bar is a metric unit of pressure, defined as 100,000 Pascals (Pa). While not an SI unit, it is commonly used in meteorology and engineering, especially for high-pressure measurements.
Suppose you have a pressure of 10197.16 mmWC.
To convert it to bar:
10197.16 mmWC ÷10197.16=1 bar
So, 10197.16 mmWC is equal to 1 bar.
Millimeter of Water Column (mmWC)Bar
100 mmWC0.0098 bar
500 mmWC0.0490 bar
1000 mmWC0.0981 bar
5000 mmWC0.4904 bar
10000 mmWC0.9808 bar
10197.16 mmWC1 bar
50000 mmWC4.9020 bar
100000 mmWC9.8041 bar
  • HVAC Systems: Convert mmWC to bar for accurate pressure readings in air-conditioning and ventilation systems.
  • Process Instrumentation: Useful for converting low-pressure readings from mmWC to bar in control and monitoring systems.
  • Pneumatics and Hydraulics: Ideal for fluid system pressure conversions.
  • Water Treatment Plants: Ensures accurate conversions in systems where water column pressure is measured.
This tool is designed for professionals in engineering, process control, HVAC, and other fields where precision in pressure conversion is required.
Pressure in bar can be converted to millimeters of water column (mmWC) by applying the following conversion factor:
1 bar = 10,197.162 mmWC
One bar of pressure therefore corresponds to the pressure produced by a 10197.162 mm tall column of water at 4°C under normal gravity.
No, 1 mmWC is far smaller than 1 bar.
Specifically:
1 mmWC = 9.8 × 10⁻⁵ bar
= 9.8 × 10⁻⁸ mbar
= 0.0014 psi
= 0.0098 kilopascal (kPa)
mmWC is millimeters of water column.
At 4°C under normal gravity, it is a pressure measuring device indicating the pressure produced by a vertical column of water precisely 1 millimeter high. Common low-pressure uses include:
  • Gas pressure measurements
  • HVAC systems
  • Fluid flow experiments
One bar is around 10,197.162 mmWC.
This is predicated on the conventional gravity and water density at 4°C. Always make sure appropriate unit conversions depending on the needed accuracy and use.
Standard symbols for millimeters of water column are:
mmWC
mmH2O
Used interchangeably, these symbols indicate the same unit of low-pressure measurement.
Inch WC also spelled in. WC, “WC, or inH2O refers to inches of water column, a unit used to gauge low pressure differentials.
Common applications include:
  • HVAC systems (e.g., before/after a coil)
  • Lines of gas pressure
  • Monitoring of Airflow
  • Measurements of industrial differential pressure
mbar is millibar, a pressure unit mostly used in meteorology.
1 mbar = 1/1000 bar = 100 pascals (Pa)
Usually between 100 and 1050 mbar in normal weather circumstances, millibars are often used in weather forecasting to indicate air pressure.
1 bar is equal to approximately 10,197.162 millimeters of water column (mmWC). This conversion is based on standard gravity (9.80665 m/s²) and water density at 4°C (1000 kg/m³). Always verify the conversion constants if high precision is required for your application.
Yes, 1 kilogram per square centimeter (kg/cm²) is equal to 10,000 mmWC, assuming water at 4°C and standard gravity. This is a commonly used approximation in industrial and HVAC pressure measurement contexts.
A pressure of 500 millibar (mbar) is equivalent to approximately 5098.6 mmWC, based on the standard conversion factor where 1 mbar = 10.19716 mmWC.
Industrial automation, HVAC systems, and scientific uses all depend critically on pressure measurement. Pressure levels could be stated in several units depending on the area, industry, or equipment used: psi, bar, kg/cm², mmWC, mmHg, and Pascal. We have included a collection of fast and accurate pressure unit conversion calculators to streamline your work. These instruments provide consistent and dependable unit conversions over a range of pressure scales whether your work involves engineering calculations, reporting, or calibration.
  1. Millibar (mBar) to Psi Pressure Unit Conversion Calculator
  2. Psi to Kg/cm² Pressure Unit Conversion Calculator
  1. Kg/cm² to Psi Pressure Unit Conversion Calculator
  2. Bar to Psi Pressure Unit Conversion Calculator
  3. Psi to KPa Pressure Unit Conversion Calculator
  4. Millimeter of Mercury (mmHg) to Psi Pressure Unit Conversion Calculator
  5. Kg/cm² to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  6. Millibar (mbar) to Pascal (Pa) Pressure Unit Conversion Calculator
  7. Inch of Water (inH₂O) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
