This calculator enables you to convert pressure values from Millimeters of Mercury (mmHg) to Inches of Water (inH₂O), a useful conversion in HVAC, medical, and laboratory settings.
Definition: Millimeter of Mercury (mmHg)
The Millimeter of Mercury (mmHg) is a unit of pressure representing the force exerted by a 1-millimeter column of mercury at 0°C under standard gravity. It is frequently used in barometric measurements, medical applications, and vacuum systems.
Definition: Inch of Water (inH₂O)
The Inch of Water (inH₂O) is a unit of pressure that represents the pressure exerted by a 1-inch column of water at 4°C. This unit is commonly used in HVAC, fluid dynamics, and other applications that involve low-pressure measurements.
Formula for mmHg to inH₂O Conversion:
Pressure in inH₂O=Pressure in mmHg×0.53524
How to Convert mmHg to inH₂O: Example Calculation
Suppose you have a pressure of 50 mmHg. To convert it to inH₂O:
50 mmHg×0.53524=26.762 inH₂O
So, 50 mmHg is equal to approximately 26.76 inH₂O.
Quick Reference Conversion Table for mmHg to inH₂O
Millimeter of Mercury (mmHg) | Inch of Water (inH₂O) |
1 mmHg | 0.53524 inH₂O |
5 mmHg | 2.6762 inH₂O |
10 mmHg | 5.3524 inH₂O |
50 mmHg | 26.762 inH₂O |
100 mmHg | 53.524 inH₂O |
Uses of mmHg to inH₂O Conversion Calculator:
- HVAC Systems: Useful for converting pressure readings in ventilation and air handling systems.
- Medical Equipment: Helps in calibrating devices where both mmHg and inH₂O are used.
- Fluid Dynamics: Essential for applications in water column and mercury column measurements.
- Scientific Research: Used in lab settings to convert low-pressure values for precision testing.
This mmHg to inH₂O conversion calculator is a valuable tool for professionals in HVAC, medical, and scientific research applications requiring accurate pressure conversions.
