Kilopascal (kPa) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
This calculator allows you to easily convert pressure values from Kilopascal (kPa) to Millimeter of Water Column (mmWC), commonly used in HVAC, water systems, and low-pressure industrial applications.
The Kilopascal (kPa) is a metric unit of pressure equal to 1000 Pascals (Pa). It is widely used in industrial, scientific, and engineering fields to measure both low and high pressures.
The Millimeter of Water Column (mmWC) is a unit that represents the pressure exerted by a 1-millimeter column of water. It is typically used for low-pressure applications such as HVAC systems, water distribution, and ventilation.
Suppose you have a pressure of 5 kPa.
To convert it to mmWC:
5×101.9716=509.858 mmWC
So, 5 kPa is equal to 509.858 mmWC.
Kilopascal (kPa)Millimeter of Water Column (mmWC)
1 kPa101.97 mmWC
2 kPa203.94 mmWC
5 kPa509.86 mmWC
10 kPa1019.72 mmWC
20 kPa2039.44 mmWC
  • HVAC and Ventilation Systems: Convert kPa readings to mmWC for precise pressure control in heating, cooling, and ventilation systems.
  • Water Distribution: Useful for converting medium to low-pressure readings in water systems where pressure is measured in mmWC.
  • Industrial Applications: Applicable for converting pressure values in process control systems, instrumentation, and calibration.
This kPa to mmWC conversion calculator is a vital tool for professionals working in fields requiring quick and accurate conversions for low-pressure systems.
