Kg/cm² to Psi Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from converting kilograms per square centimeter (kg/cm²) to pounds per square inch (psi):
A kilogram per square centimeter (symbol: kg/cm²) is a unit of pressure where one kilogram-force is applied over an area of one square centimeter. This unit is commonly used in fields such as material science and engineering.
Suppose you have a pressure of 2 kg/cm².
  • To convert it to psi: 2 × 14.2233 = 28.4466 psi
  • So, 2 kg/cm² is equal to 28.4466 psi.
Here’s a quick reference table for common kg/cm² values to psi:
kg/cm² (kilogram per square centimeter)Psi (pound-force per square inch)
0.1 kg/cm²1.42233 psi
0.5 kg/cm²7.11165 psi
1 kg/cm²14.2233 psi
2 kg/cm²28.4466 psi
3 kg/cm²42.6699 psi
5 kg/cm²71.1165 psi
10 kg/cm²142.233 psi
20 kg/cm²284.466 psi
50 kg/cm²711.165 psi
100 kg/cm²1422.33 psi
  • Engineering Applications: Convert pressures in mechanical systems, including automotive and aerospace engineering.
  • Instrumentation: For converting pressure readings from metric units to imperial units in various industrial applications.
This calculator is particularly useful in fields that frequently deal with high pressures, such as material science, manufacturing, and heavy machinery industries.
Here you can refer more Online Instrumentation Calculators Collections
