This calculator allows you to convert pressure values from converting kilograms per square centimeter (kg/cm²) to pounds per square inch (psi):
Definition: Kilogram per Square Centimeter (kg/cm²)
A kilogram per square centimeter (symbol: kg/cm²) is a unit of pressure where one kilogram-force is applied over an area of one square centimeter. This unit is commonly used in fields such as material science and engineering.
Definition: Pound-force per Square Inch (psi)
Formula for kg/cm² to Psi Conversion:
Pressure in psi = Pressure in kg/cm² × 14.2233
How to Convert kg/cm² to Psi: Example Calculation
Suppose you have a pressure of 2 kg/cm².
- To convert it to psi: 2 × 14.2233 = 28.4466 psi
- So, 2 kg/cm² is equal to 28.4466 psi.
Quick Reference Conversion Table for kg/cm² to Psi
Here’s a quick reference table for common kg/cm² values to psi:
| kg/cm² (kilogram per square centimeter) | Psi (pound-force per square inch) |
| 0.1 kg/cm² | 1.42233 psi |
| 0.5 kg/cm² | 7.11165 psi |
| 1 kg/cm² | 14.2233 psi |
| 2 kg/cm² | 28.4466 psi |
| 3 kg/cm² | 42.6699 psi |
| 5 kg/cm² | 71.1165 psi |
| 10 kg/cm² | 142.233 psi |
| 20 kg/cm² | 284.466 psi |
| 50 kg/cm² | 711.165 psi |
| 100 kg/cm² | 1422.33 psi |
Use of kg/cm² to Psi Conversion Calculator:
- Engineering Applications: Convert pressures in mechanical systems, including automotive and aerospace engineering.
- Instrumentation: For converting pressure readings from metric units to imperial units in various industrial applications.
This calculator is particularly useful in fields that frequently deal with high pressures, such as material science, manufacturing, and heavy machinery industries.
