This calculator provides a simple way to convert pressure values from Inch of Water (inH2O) to Standard Atmosphere (atm), a common requirement in scientific, meteorological, and industrial applications involving low-pressure measurements.
Definition: Inch of Water (inH2O)
The Inch of Water (inH2O) is a unit of pressure representing the pressure exerted by a 1-inch column of water under standard gravity. It is commonly used in HVAC, airflow measurements, and fluid flow systems.
Definition: Standard Atmosphere (atm)
The Standard Atmosphere (atm) is a unit of pressure defined as exactly 101,325 Pascals, which is the average atmospheric pressure at sea level. It is widely used in scientific research, engineering, and environmental sciences.
Formula for inH2O to atm Conversion
Pressure in atm=Pressure in inH2O×0.002458
How to Convert inH2O to atm: Example Calculation
Suppose you have a pressure of 50 inH2O. To convert it to atm:
50?inH2O×0.002458=0.1229?atm
So, 50 inH2O is approximately equal to 0.1229 atm.
Quick Reference Conversion Table for inH2O to atm
Inch of Water (inH2O) | Standard Atmosphere (atm) |
1 inH2O | 0.002458 atm |
5 inH2O | 0.01229 atm |
10 inH2O | 0.02458 atm |
25 inH2O | 0.06145 atm |
50 inH2O | 0.1229 atm |
100 inH2O | 0.2458 atm |
Uses of inH2O to atm Conversion Calculator
- HVAC and Ventilation: Helps in converting low-pressure readings for duct and airflow systems.
- Fluid Mechanics: Used in applications that require the conversion of fluid pressure from inH2O to atm.
- Environmental Science: Useful in measuring and comparing atmospheric pressures.
- Industrial Calibration: Essential for converting inH2O to atm in process control tasks.
This inH2O to atm conversion calculator is a valuable tool for professionals in engineering, meteorology, and various scientific fields where accurate pressure conversions are required.
