Gallons per Minute (GPM) to Gallons per Hour (GPH) Flow Unit Conversion Calculator
This tool allows users to convert Gallons per Minute (GPM) to Gallons per Hour (GPH), thereby easily scaling flow rates for longer times. Perfect for process control, fluid distribution, and irrigation applications where flow uniformity is vital over time.
A U.S. conventional unit, gallons per minute (GPM) gauges the volume of fluid flowing every minute, usually for uses demanding real-time flow evaluation including pumping systems, cooling loops, and industrial fluid transfer.
  • Pumping Systems: Establishes output capacity in real time.
  • Cooling Systems: Controls flow to regulate temperature.
  • Measures hose and sprinkler water delivery rate.
  • Water Treatment: Observes tank, membrane, and filter flow.
 Another U.S. conventional unit measuring flow over an hourly period is Gallons per Hour (GPH). Common applications include irrigation, fuel dosing, and processes where fluids are handled constantly throughout time..
  • Irrigation Systems: Irrigation systems control water distribution to plants over long periods.
  • Fuel Injection and Distribution: Tracks flow in industrial and automotive systems.
  • HVAC Systems: Used for loop monitoring of heating/cooling, HVAC systems
  • Chemical Processing: Aids in controlling fluid dosage and additives in chemical processing..
This formula will help you to change Gallons per Minute (GPM) into Gallons per Hour (GPH):
This is because there are 60 minutes in an hour, so a constant flow in GPM scales by 60 to reflect hourly flow.
Convert 25 GPM to GPH:
25×60=1,500 GPH25
Thus, 25 GPM equals 1,500 Gallons per Hour.
Gallons per Minute (GPM)Gallons per Hour (GPH)
1 GPM60 GPH
5 GPM300 GPH
10 GPM600 GPH
25 GPM1,500 GPH
50 GPM3,000 GPH
100 GPM6,000 GPH
  •  Scale From real-time measurements to hourly data for improved fluid system design.
  • Design for Continuous Operations in irrigation and chemical dosing should be simplified.
  • For more adaptable system design, change between typical U.S. flow units.
  • Assist Documentation and Reporting in time-based flow metric facilities.
  • In different industrial processes, optimize fluid and water management.
Engineers, technicians, and facility managers dealing with fluid systems where real-time flow data must be converted into more general operational parameters will find this conversion calculator indispensable.
