This tool helps users convert Gallons per Day (GPD) to Liters per Minute (L/min), supporting professionals in water treatment, filtration systems, and fluid dosing operations where converting long-duration U.S. customary units into real-time metric flow is essential.
Definition: Gallons per Day (GPD)
Commonly used in the U.S. for low-flow applications such water filtration, irrigation, and dosing systems, Gallons per Day (GPD) is a unit of volume flow measuring the total volume of fluid moved or processed in a 24-hour period.
Key Applications of Gallons per Day (GPD):
- Reverse Osmosis Systems: Rates membrane capacity and permeate flow rates.
- Water Filtration Units: Indicates commercial and household filter throughput.
- Chemical Dosing Pumps: Calculates daily cycle chemical delivery.
- Irrigation Systems: Irrigation systems control ongoing and gradual watering activities.
Definition: Liters per Minute (L/min)
A metric quantity called liters per minute (L/min) indicates the volume of fluid moved every minute. It is often used in real-time flow monitoring, dosing systems, and industrial applications requiring continuous flow measurement.
Key Applications of Liters per Minute (L/min):
- Plumbing and Piping Systems: Tracks appliance and fixture water flow.
- Medical Equipment: Used in oxygen concentrators and IV delivery systems.
- Process Automation: Monitors mixing and dosing in real-time.
- Industrial Machinery: Measures flow in transfer, lubrication, and cooling systems.
Formula for GPD to L/min Conversion
This formula will help you to convert Gallons per Day (GPD) to Liters per Minute (L/min):
Flow (L/min)=Flow (GPD)×0.002630
1 U.S. gallon = 3.78541 liters and 1 day = 1,440 minutes,
so:
GPD × 3.78541 ÷ 1,440 = GPD × 0.002630 L/min
Example Calculation
Convert 5,000 GPD to L/min:
5,000×0.002630=13.15 L/min
Thus, 13.15 Liters per Minute is the equivalent to 5,000 GPD.
Gallons per Day (GPD) | Liters per Minute (L/min) |
100 GPD | 0.263 L/min |
500 GPD | 1.315 L/min |
1,000 GPD | 2.63 L/min |
2,000 GPD | 5.26 L/min |
5,000 GPD | 13.15 L/min |
10,000 GPD | 26.3 L/min |
Uses of GPD to L/min Conversion
- Translate Long-Term Flows to Real-Time Rates for better monitoring and control.
- Optimize Filtration and RO Systems with accurate real-time flow metrics.
- Follow Metric Standards to ensure worldwide equipment compatibility.
- Assist in Mixing and Dosing Activities where flow uniformity is critical.
- Assist international projects needing dual-unit system integration to integrate dual-unit systems.
This conversion tool helps experts build, monitor, and troubleshoot systems with precision and worldwide uniformity by linking daily volume measurements to minute-by-minute flow control.
