HomeInstrumentation CalculatorsCubic Meters per Second (m³/s) to Cubic Feet per Second (ft³/s) Flow...
Cubic Meters per Second (m³/s) to Cubic Feet per Second (ft³/s) Flow Unit Conversion Calculator
Published on
spot_img
The tool enables users to convert their Cubic Meters per Second (m³/s) values into the industrial-standard Cubic Feet per Second (ft³/s). The conversion enables hydraulic system design work as well as river water flow assessments and industrial fluid management system optimization.
The SI unit for measuring fluid volume passed through a specific point per second goes by the name Cubic Meter per Second (m³/s). As a vital measurement method hydrologists along with engineers and industrial operators use to assess large-scale fluid movements.
  • River and canal water flow receives measurement through cubic meter per second (m3/s).
  • Designing municipal water distribution systems.
  • Industrial cooling and processing.
The US conventional measurement system and imperial unit for expressing volumetric flow rate is known as the Cubic Foot per Second (ft³/s). A cubic foot has an equivalent value of 0.0283168 cubic meters. This unit serves as an essential measurement tool throughout the United States for hydrological examinations and establishing wastewater discharge as well as streamflow determination.
  • Monitoring stream and river discharges.
  • Engineers use this unit during flood control and drainage system design.
  • The process of fluid flow calculation requires engineering applications.
The conversion between cubic meters per second (m³/s) and cubic feet per second (ft³/s) requires the following formula:
Since 1 cubic meter is equal to 35.3147 cubic feet, multiplying the flow rate in m³/s by this factor will provide the equivalent value in ft³/s.
Suppose you have a flow rate of 2 m³/s. To convert it to ft³/s:
2 × 35.3147 = 70.6294 ft³/s
So, 2 m³/s is equivalent to 70.63 ft³/s (rounded to two decimal places).
Cubic Meters per Second (m³/s)Cubic Feet per Second (ft³/s)
1 m³/s35.31 ft³/s
5 m³/s176.57 ft³/s
10 m³/s353.15 ft³/s
50 m³/s1,765.74 ft³/s
100 m³/s3,531.47 ft³/s
  • Hydrology & Environmental Studies make use of this conversion to determine river discharge and predict floods while managing stormwater operations.
  • Water Resource Engineering benefits from pipeline and dam and irrigation network optimization through its design capabilities.
  • The cooling water systems and chemical processing operations alongside wastewater management in industrial and power plants utilize this measurement.
  • Municipal water supply uses this tool to evaluate the distribution system and treatment facilities’ maximum capacity for flow.
Engineering teams and professionals in hydrology and industrial water management continuously need this m³/s to ft³/s conversion resource because it serves their purpose in fluid dynamics applications and water-related projects. The accurate understanding of this conversion leads to precise fluid transport calculations as well as enhanced operational flow management system that produces better operational efficiency.
Latest articles
Cubic Meters per Minute (m³/min) to Gallons per Minute (GPM) Flow Unit Conversion Calculator
Users can use the tool to convert measurement data in m³/min into the commonly...
Gallons per Minute (GPM) to Cubic Meters per Hour (m³/h) Flow Unit Conversion Calculator
You can use this converter to process Gallons per Minute (GPM) into the preferred...
Gallons per Minute (GPM) to Cubic Feet per Second (ft³/s) Flow Unit Conversion Calculator
This tool enables the conversion of Gallons per Minute (GPM) into the commonly used...
Barrels per Day (BPD) to Cubic Meters per Hour (m³/h) Flow Unit Conversion Calculator
The tool allows users to convert their Barrels per Day (BPD) data into the...
More like this
