Control Narrative
What is the control narrative?
A system control philosophy is a document that contains a description of the operating philosophies prepared by process engineers.
The control narrative describes the control philosophy as well as the variables in the control program. Field instrument parameters, pumps, valves, and other process equipment status signals are examples of variables.
Detailed Explanation of Control Narrative
A statement of the main operating principles is found in a document called a system control philosophy. The Control Narrative describes the control philosophy and identifies the control program’s variables. Alarm set points and shutdown values are typically described in control narratives.
The control narrative specifies the conditions for the system’s programming. The Control Narrative explains the plant operation philosophy and variables to be involved in the control program. Variables include field instrument parameters, pump, valve, and other equipment status signals, and field instrument, equipment, and smart safety relay information. A control philosophy improves definitions, concepts, and procedures during design and implementation.
What is the purpose of a control narrative?
Most of the time control narratives are used for three reasons. Control narratives provide:
  • Process engineers have the chance to set out and record operational procedures on the plant floor.
  •  Documentation for operator training and comprehension of the process’s equipments, variables, For all processes, the control narrative should always be included in the skill block handbook and new operator training materials.
  • A starting point for control system programmers to write configuration code for the control system that will control the process, even if they have little experience with that particular process.
Overall, the purpose of a control narrative is to provide a comprehensive understanding of the process and its performance, which in turn can be used as a base to develop control logics for DCS/PLC systems by automation engineers.
What is included in Control Narrative?
A Control Narrative includes:
  • Process Overview: Basic description of the overall system process, including its purpose, process timeline by functional unit, major functional unit descriptions, basic description of the subsystem process, and how it works with utilities.
  • Equipment List: A complete list of all the physical equipment used in the process. Some of these are motors, valves, transmitters, and so on.
  • Software Components: Non-physical devices that are involved in the process. Control loops, totalizers, calculations, and parameters are examples of these.
  • Alarms: All non-default alarms linked with the process are defined here. These alarms will be shown in a number of places on the user interface.
  • Process Functionality Description (Interlock and sequence): Sequence descriptions are step-by-step procedures that explain how the unit works.
A. Sequence Area
1. Sequence Set Points
a. Sequence Steps
Interlocks are any corrective actions that are meant to protect the product, people, or equipment.
Concurrent Tasks: A definition of all normal process control functions that work independently of the sequences.
The chart below is an example of a control narrative chart.
control narrative chart 1
control narrative chart 2
  • Document the intent and rationale behind control configurations, complementing technical design documents that describe the implementation details.
  • Provide a clear reference for programming, troubleshooting, and validating system behavior.
  • Parameter List
    • Use a structured format (e.g., spreadsheet) to include key information such as module names, I/O details, alarm settings, and tuning constants.
    • Include a notes section for describing simple logic or operational behaviors.
  • Detailed Logic Descriptions
    • Provide concise explanations for complex control logic, such as interlocks, cascading, or ratio controls.
    • Cross-reference these descriptions with the parameter list for consistency.
  • Process Flow Diagrams
    • Create flow diagrams for individual control phases or sequences, detailing parameters, logic paths, and failure modes.
    • Develop flowcharts for operational workflows to show how phases interact and parameters are passed between them.
  • Begin with a high-level process description from the relevant process owner or engineer.
  • Gradually expand into a detailed functional specification, documenting:
    • Normal operational sequences.
    • Control logic responsibilities (e.g., system vs. operator actions).
    • Expected responses to specific inputs and failure scenarios.
  • Use a modular approach to ensure clarity and reusability.
  • Maintain a consistent structure across documents to improve readability and ease of use.
  • Incorporate visuals (e.g., flowcharts, diagrams) to enhance understanding of complex logic.
  • Include input from all relevant stakeholders, such as process engineers, operators, and maintenance teams.
  • Use accessible language to ensure non-technical stakeholders can understand the logic without specialized knowledge.
  • Follow industry-recognized standards to ensure completeness and compatibility with broader system requirements.
  • Use these standards to define: The level of detail required in the narrative, Key elements like sequence descriptions, responsibilities, and exceptions.
The control narrative philosophy outlines the operating principles and key variables of a control program. It provides context for how automation and processes are designed to function, typically including:
  • The control narrative, which details programming conditions and the system’s expected behavior.
  • The plant’s operation philosophy, explaining how processes should align with broader operational goals.
  • Specifications such as alarm set points and shutdown values, ensuring safe and efficient operation.
The control narrative document is a formal description of how a process and its automation systems are expected to function. It serves as a bridge between the process design and the control system implementation, offering:
  • A clear explanation of the process behavior and automation logic.
  • Comprehensive guidance for system programmers and operators.
  • A way to address gaps caused by insufficient documentation or comments in the code.
This document ensures all stakeholders have a shared understanding of the system’s design and operation.
A control narrative in engineering documentation specifies how the control system should operate under various conditions. It translates the high-level process requirements into operational logic, enabling consistent implementation and testing. Key elements include:
  • Descriptions of process behavior.
  • Expected system responses to various inputs and scenarios.
  • Integration with broader operational objectives.
The functional description and control narrative serve different purposes in system documentation:
AspectControl NarrativeFunctional Description
PurposeHigh-level overview of system functionality.Detailed specification of system design.
FocusOperational philosophy and expected outcomes.Technical details for implementation.
Detail LevelConceptual and general with some specific details.Comprehensive and highly detailed.
AudienceEngineers, operators, and non-technical stakeholders.Programmers, system designers, and testers.
ContentDescribes process behavior and system responses.Includes logic diagrams, parameter settings, and I/O relationships.
Use CaseProvides context and guidance for system understanding.Serves as a blueprint for precise system configuration.
ExamplesExpected operation sequences.Alarm and shutdown pointsLogic flowcharts.Tuning constants and parameter lists.
