Commissioning of Wet Leg Level Measurement in Process Area Quiz with 25 Practical Engineering Questions
Wet leg level measurement is widely used for closed and pressurized vessels where vapor pressure must be compensated during differential pressure level measurement. Incorrect reference leg filling, trapped gas, leakage, incorrect specific gravity, impulse line problems or manifold operation can produce significant level errors.
Effective wet leg commissioning requires more than checking the transmitter output. Engineers must verify the complete pressure measurement path, including vessel connections, wet reference leg, impulse lines, manifold valves, transmitter calibration, 4 to 20 mA output and DCS scaling.
This quiz tests practical wet leg level measurement knowledge using genuine conditions usually encountered during pre commissioning, commissioning, start up, maintenance and plant operation. The questions emphasize engineering calculations, field verification, troubleshooting and commissioning judgment.
Test Your Wet Leg Level Measurement Commissioning Knowledge
The following questions cover advanced wet leg DP transmitter commissioning problems involving LRV and URV calculation, zero elevation, reference leg filling, impulse lines, manifold operation, DCS verification and field troubleshooting. Read each situation carefully and select the most appropriate engineering answer.
An instrumentation engineer wants to prevent recurring wet leg level measurement problems across a process plant. Which practice provides the strongest long term benefit?
A commissioning engineer calculates LRV and URV correctly but discovers that the DCS shows 100 percent when the transmitter is physically at 50 percent. The transmitter output and range are verified. What should be investigated?
A wet leg level transmitter is showing a sudden shift immediately after a technician operates the manifold. The process level has not changed. Which condition is most likely?
A wet leg transmitter reads correctly during calibration with a test pressure source. After returning the process to service, the reading becomes low. The transmitter range is confirmed correct. Which field condition should receive priority?
A wet leg transmitter shows an unexpectedly negative DP at minimum process level. The wet leg height and reference liquid specific gravity have been confirmed. What does the negative DP indicate?
During loop checking, the transmitter is ranged from minus 2500 to plus 500 mmH2O. At a differential pressure of minus 1000 mmH2O, what output should a linear transmitter produce?
A closed vessel contains process liquid with specific gravity 0.90. The wet reference leg is 3 m high with specific gravity 1.0. The process level range is 0 to 4 m. What are the LRV and URV in mmH2O?
A wet leg transmitter is being commissioned on a hot hydrocarbon vessel. The reference leg and manifold must be inspected. Which approach is most appropriate?
A DCS indicates 60 percent level while the transmitter local display indicates 40 percent. Measurement pressure is verified as correct and the transmitter produces the expected 10.4 mA output for its configured range. What should be investigated?
A wet leg transmitter is stable during commissioning, but the level reading gradually drifts over several days. The process level is independently confirmed as stable. Which condition is particularly important to investigate?
After impulse line maintenance, a transmitter indication becomes unstable while the vessel level is steady. The wet leg was correctly filled before maintenance. What should be investigated?
A wet leg transmitter reads correctly at zero level during commissioning but shows an incorrect full scale value. The wet leg height and reference liquid are verified. Which calculation should be reviewed?
A wet leg transmitter has an LRV of minus 2000 mmH2O and a URV of 1000 mmH2O. What differential pressure corresponds to 75 percent level?
A five valve manifold is being returned to service after maintenance. The transmitter indication suddenly becomes abnormal. Which item should be verified before changing calibration?
During commissioning, the wet leg transmitter reads lower than the actual level. The reference liquid specific gravity is found to be higher than the value used during calibration. What is the likely effect?
A DP transmitter is mounted below the lower vessel tapping point. The high pressure impulse line remains filled with process liquid. What installation effect must be considered during calibration?
A wet reference leg is 4 m high and contains water with specific gravity 1.0. Assume 1 m water head produces approximately 9.81 kPa. What pressure does the wet leg produce?
A DP transmitter passes bench calibration successfully. After connection to a pressurized separator, the DCS level is incorrect. The transmitter configuration remains unchanged. What should be checked first?
A transmitter has an LRV of minus 1200 mmH2O and a URV of minus 200 mmH2O. What differential pressure corresponds to 50 percent output?
During commissioning of a pressurized vessel, the transmitter indication changes whenever vessel pressure changes even though the actual liquid level remains constant. Which condition should be investigated first?
A wet leg transmitter indicates a higher level than the actual process level after several weeks of operation. The original calibration was correct. The reference leg is suspected of losing liquid. Why would this condition produce a higher level indication?
A wet leg transmitter has an LRV of minus 1800 mmH2O and a URV of 600 mmH2O. What is the transmitter span?
A closed vessel contains liquid with a specific gravity of 0.80. The level range is 0 to 3000 mm. The wet reference leg is 2500 mm high and contains liquid with specific gravity 1.0. What are the LRV and URV in mmH2O?
A closed separator uses a wet leg because the vapor above the process liquid can condense. During commissioning, the engineer discovers that the reference leg contains air pockets. What is the most likely effect?
A DP level transmitter is installed on a closed process vessel. The low pressure side is connected through a completely filled wet reference leg. What is the primary purpose of maintaining the wet leg completely filled?
The average score is 48%
#WetLegLevelMeasurement #WetLegCalibration #DPTransmitter #LevelMeasurement #InstrumentationEngineering #AutomationEngineering #ControlEngineering #ProcessControl #IndustrialAutomation #Instrumentation #ProcessIndustry #PlantCommissioning #LevelTransmitter #WetReferenceLeg #DifferentialPressure #ProcessInstrumentation #InstrumentationCommissioning #LevelMeasurementTroubleshooting #DPTransmitterCommissioning #ProcessPlant
