This calculator helps you convert pressure values from Standard Atmosphere (atm) to Inch of Water (inH2O), a commonly used unit in HVAC systems, fluid dynamics, and industrial applications involving low-pressure measurements.
Definition: Standard Atmosphere (atm)
The Standard Atmosphere (atm) is a unit of pressure equivalent to 101,325 Pascals, representing the average atmospheric pressure at sea level. It is widely used in scientific research and engineering.
Definition: Inch of Water (inH2O)
The Inch of Water (inH2O) is a pressure unit that represents the pressure exerted by a 1-inch column of water under standard gravity. It is commonly applied in HVAC, airflow measurements, and liquid level monitoring.
Formula for atm to inH2O Conversion
Pressure in inH2O=Pressure in atm×407.184
How to Convert atm to inH2O: Example Calculation
Suppose you have a pressure of 0.5 atm. To convert it to inH2O:
0.5 atm×407.184=203.592 inH2O
So, 0.5 atm is approximately equal to 203.59 inH2O.
Quick Reference Conversion Table for atm to inH2O
Standard Atmosphere (atm) | Inch of Water (inH2O) |
0.1 atm | 40.7184 inH2O |
0.5 atm | 203.592 inH2O |
1 atm | 407.184 inH2O |
2 atm | 814.368 inH2O |
5 atm | 2035.92 inH2O |
Uses of atm to inH2O Conversion Calculator
- HVAC and Ventilation Systems: Helps convert barometric pressure to inH2O for duct pressure calculations.
- Fluid Mechanics: Converts high-pressure measurements to inH2O for better precision in liquid systems.
- Industrial Processes: Useful for pressure standardization in low-pressure systems.
- Environmental Studies: Facilitates conversion of atmospheric pressure for scientific studies.
This atm to inH2O conversion calculator is an essential tool for professionals in engineering, environmental science, and fluid dynamics needing accurate pressure unit conversions.
