Proximity Switch – MCQ1
    0
    177
    ","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:90:\"Which of the following is NOT a factor that influences a proximity switch's sensing range?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["The sensing object's material",0,0],["Outside temperature",0,0],["Switch housing parameters",0,1],["Power supply voltage",0,0]]},"664":{"question_id":"664","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:24:\"Optical proximity switch\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:24:\"Optical proximity switch\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:25:\"Magnetic proximity switch\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:19:\"All mentioned above\";i:1;d:0;i:2;i:1;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"
    Explanation:\u00a0 <\/span>There are several different kinds of proximity switches that can sense the presence of an object without coming into touch with it, including optical, magnetic, and capacitive switches.<\/span><\/p>
    ","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:57:\"Which of the following describes a proximity switch type?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Optical proximity switch",0,0],["Optical proximity switch",0,0],["Magnetic proximity switch",0,0],["All mentioned above",0,1]]},"665":{"question_id":"665","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:58:\"The distance between the switch and the thing being sensed\";i:1;d:0;i:2;i:1;}i:1;a:3:{i:0;s:31:\"The size of the detected object\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:48:\"The material of which the object is manufactured\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:38:\"The temperature of the detected object\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"
    Explanation:\u00a0 The sensing range of a proximity switch is the distance between the switch and the thing being sensed.<\/span><\/p>","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:43:\"What is a proximity switch's sensing range?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["The distance between the switch and the thing being sensed",0,1],["The size of the detected object",0,0],["The material of which the object is manufactured",0,0],["The temperature of the detected object",0,0]]},"666":{"question_id":"666","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:24:\"Sensing range limitation\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:43:\"Exposure to interference from ambient light\";i:1;d:0;i:2;i:1;}i:2;a:3:{i:0;s:9:\"Expensive\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:28:\"Difficulty with installation\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"
    Explanation:\u00a0<\/span>The accuracy of optical proximity switches might be reduced by interference from background light.<\/span><\/p>","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:81:\"Which of the following is not a benefit of utilizing an optical proximity switch?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Sensing range limitation",0,0],["Exposure to interference from ambient light",0,1],["Expensive",0,0],["Difficulty with installation",0,0]]},"667":{"question_id":"667","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:18:\"Wide sensing range\";i:1;d:0;i:2;i:1;}i:1;a:3:{i:0;s:47:\"The ability to detect a wide range of materials\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:9:\"Low price\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:17:\"Simple to install\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation: Because magnetic proximity switches have a broad detecting range, they are suited for use in applications where objects are moving swiftly or at a distance.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:61:\"What is the benefit of employing a magnetic proximity switch?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Wide sensing range",0,1],["The ability to detect a wide range of materials",0,0],["Low price",0,0],["Simple to install",0,0]]},"668":{"question_id":"668","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:25:\"Detection of metal things\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:33:\"Detection of non-metallic objects\";i:1;d:0;i:2;i:1;}i:2;a:3:{i:0;s:57:\"Detecting things in an environment with high temperatures\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:38:\"Detecting things in a cold environment\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation : Because capacitive proximity switches are excellent at detecting non-metallic materials like plastic or wood.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:68:\"Which of the following is a capacitive proximity switch application?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Detection of metal things",0,0],["Detection of non-metallic objects",0,1],["Detecting things in an environment with high temperatures",0,0],["Detecting things in a cold environment",0,0]]},"669":{"question_id":"669","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:35:\"When there is an object, it is open\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:37:\"When there is an object, it is closed\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:38:\"It is open in the absence of an object\";i:1;d:0;i:2;i:1;}i:3;a:3:{i:0;s:40:\"When no object is present, it is closed.\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation : An object is identified when a normally open proximity switch is closed, which means that it is open while no object is present.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:73:\"What is the correct description of a normally open (NO) proximity switch?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["When there is an object, it is open",0,0],["When there is an object, it is closed",0,0],["It is open in the absence of an object",0,1],["When no object is present, it is closed.",0,0]]},"670":{"question_id":"670","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:35:\"When there is an object, it is open\";i:1;d:0;i:2;i:1;}i:1;a:3:{i:0;s:38:\"When there is an object, it is closed.\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:38:\"It is open in the absence of an object\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:37:\"It is shut while nothing is in sight.\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation: A normally closed proximity switch remains closed in the absence of an object and opens when one is found.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:75:\"What is the correct description of a normally closed (NC) proximity switch?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["When there is an object, it is open",0,1],["When there is an object, it is closed.",0,0],["It is open in the absence of an object",0,0],["It is shut while nothing is in sight.",0,0]]},"671":{"question_id":"671","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:24:\"Sensing range limitation\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:42:\"Exposure to interference from other things\";i:1;d:0;i:2;i:1;}i:2;a:3:{i:0;s:9:\"Expensive\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:27:\"Only detects metallic items\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation: Because other things in the area can interfere with capacitive proximity switches, the accuracy of these devices may be impacted.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:80:\"Which of the following is a drawback of employing a capacitive proximity switch?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Sensing range limitation",0,0],["Exposure to interference from other things",0,1],["Expensive",0,0],["Only detects metallic items",0,0]]},"672":{"question_id":"672","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:46:\"The capacity for non-metallic object detection\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:17:\"Extreme precision\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:10:\"Affordable\";i:1;d:0;i:2;i:0;}i:3;a:3:{i:0;s:18:\"Wide sensing field\";i:1;d:0;i:2;i:1;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation: Due to its broad sensing capabilities, inductive proximity switches are perfect for usage in situations where objects may be moving swiftly or far away.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:66:\"What benefit does employing an inductive proximity switch provide?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["The capacity for non-metallic object detection",0,0],["Extreme precision",0,0],["Affordable",0,0],["Wide sensing field",0,1]]},"673":{"question_id":"673","quiz_id":"43","question_name":"","answer_array":"a:4:{i:0;a:3:{i:0;s:44:\"Detecting a metallic object's existence\";i:1;d:0;i:2;i:0;}i:1;a:3:{i:0;s:47:\"Detecting a non-metallic object's presence\";i:1;d:0;i:2;i:0;}i:2;a:3:{i:0;s:35:\"Determining the liquid's level\";i:1;d:0;i:2;i:1;}i:3;a:3:{i:0;s:38:\"Measuring an object's temperature\";i:1;d:0;i:2;i:0;}}","answer_one":"","answer_one_points":"0","answer_two":"","answer_two_points":"0","answer_three":"","answer_three_points":"0","answer_four":"","answer_four_points":"0","answer_five":"","answer_five_points":"0","answer_six":"","answer_six_points":"0","correct_answer":"0","question_answer_info":"Explanation: Ultrasonic proximity switches are frequently used to determine the liquid level in tanks and other containers.","comments":"1","hints":"","question_order":"1","question_type":"0","question_type_new":"0","question_settings":"a:14:{s:8:\"required\";i:1;s:12:\"answerEditor\";s:4:\"text\";s:14:\"question_title\";s:82:\"In which of the following situations would an ultrasonic proximity switch be used?\";s:14:\"featureImageID\";s:0:\"\";s:15:\"featureImageSrc\";s:0:\"\";s:11:\"matchAnswer\";s:6:\"random\";s:14:\"case_sensitive\";s:0:\"\";s:16:\"image_size-width\";s:0:\"\";s:17:\"image_size-height\";s:0:\"\";s:8:\"autofill\";s:0:\"\";s:10:\"limit_text\";s:1:\"0\";s:23:\"limit_multiple_response\";s:1:\"0\";s:17:\"file_upload_limit\";s:1:\"0\";s:16:\"file_upload_type\";s:0:\"\";}","category":"","linked_question":"","deleted":"0","deleted_question_bank":"0","answers":[["Detecting a metallic object's existence",0,0],["Detecting a non-metallic object's presence",0,0],["Determining the liquid's level",0,1],["Measuring an object's temperature",0,0]]}},"first_page":true}
    We will discuss proximity switch questions and answers in this post, along with information on installation, troubleshooting, and operating principles. Whether you're an engineer, technician, or someone who is just curious about this technology, the questions and answers in this section will give you helpful information on proximity switches and their uses.
