This calculator allows you to easily convert pressure values from Millibar (mBar) to Torr, perfect for use in scientific, engineering, and industrial applications.
Definition: Millibar (mBar)
The Millibar (mBar) is a metric unit of pressure, commonly used in meteorology and industrial systems like pneumatics and HVAC. One Millibar is equivalent to 100 Pascals (Pa).
Definition: Torr
The Torr is a pressure unit named after Evangelista Torricelli, equivalent to 1/760th of an atmosphere (atm), commonly used in measuring vacuum pressure.
Formula for Millibar (mBar) to Torr Conversion:
Pressure in Torr=Pressure in mBar×0.750062
How to Convert Millibar to Torr: Example Calculation
Suppose you have a pressure of 500 mBar.
To convert it to Torr:
500×0.750062=375.031 Torr
So, 500 mBar is equal to approximately 375.031 Torr.
Quick Reference Conversion Table for Millibar (mBar) to Torr:
mBar | Torr |
1 mBar | 0.750062 Torr |
10 mBar | 7.50062 Torr |
100 mBar | 75.0062 Torr |
500 mBar | 375.031 Torr |
760 mBar | 570.047 Torr |
1000 mBar | 750.062 Torr |
Use of Millibar to Torr Conversion Calculator:
- Vacuum Systems: Convert mBar values to Torr for accurate pressure measurement in vacuum systems.
- Meteorology: Helpful in converting pressure readings in atmospheric studies and weather forecasts.
- Industrial Applications: Useful for converting pressure values in HVAC, refrigeration, and other low-pressure systems.
This mBar to Torr conversion calculator is an essential tool for professionals working in pressure-sensitive environments.
