Liters per Second (L/s) to Cubic Meters per Second (m³/s) Flow Unit Conversion Calculator
This tool helps users convert flow rates from Liters per Second (L/s) into Cubic Meters per Second (m³/s), a crucial conversion for professionals working in water treatment, civil engineering, and industrial process design where accurate large-scale fluid measurements are required.
A commonly used metric quantity, liters per second (L/s) shows the volume of fluid flowing per second. For moderate to high-volume flow applications in many sectors, it is perfect.
  • Often found in industrial and municipal water delivery systems.
  • Used in flow monitoring of cooling systems and HVAC.
  • Standard for precision dosing systems and laboratory fluid investigations.
  • Used in environmental engineering to measure river, stream, and flood flow.
For large-scale measurements, Cubic Meters per Second (m³/s) is the SI unit of volumetric flow rate. Given that one cubic meter equals 1,000 liters, this measure is appropriate for high-capacity industrial or natural systems.
  • Used in hydrology for measuring river discharges and flood modeling.
  • Designing and assessing wastewater treatment plants depends on essentiality.
  • Used in infrastructure projects and big industrial flow systems.
  • Essential to modeling significant fire suppression or HVAC systems.
To convert L/s to m³/s, use the following formula:
You may get the cubic meters per second by splitting the L/s figure by 1,000 since one cubic meter is 1,000 liters.
If your current flow rate is 2,500 L/s, convert it to m³/s:
2,500 L/s ÷ 1,000 = 2.5 m³/s
So, a flow rate of 2,500 L/s is equivalent to 2.5 m³/s.
Liters per Second (L/s)Cubic Meters per Second (m³/s)
1 L/s0.001 m³/s
10 L/s0.01 m³/s
100 L/s0.1 m³/s
1,000 L/s1 m³/s
2,500 L/s2.5 m³/s
5,000 L/s5 m³/s
10,000 L/s10 m³/s
  • Allows engineers to upscale flow rates for large system modeling.
  • Aids in appropriate sizing and design of drainage channels and pipelines.
  • Aids hydrologists in assessing and documenting river and stream capacities.
  • Turns pilot plant and lab results into full-scale operational terminology.
  • Helps with worldwide technological standards and compliance reporting.
Anyone who needs to accurately and consistently convert small- or medium-scale flow measurements into greater volume engineering units may find this conversion tool to be quite useful.
