Kpa to Psi Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from converting kilopascals (kPa) to pounds per square inch (psi):
A kilopascal (symbol: kPa) is a unit of pressure in the metric system. It is equal to 1,000 pascals. The kilopascal is widely used in various fields, including engineering and meteorology, to measure pressure.
Suppose you have a pressure of 500 kPa.
  • To convert it to psi: 500 × 0.1450377 = 72.51885 psi
  • So, 500 kPa is equal to 72.51885 psi.
Click here for PSI to Bar Unit Conversion Calculator
Refer the below quick reference table for common kPa values to psi:
kPa (kilopascal)psi (pound-force per square inch)
0.1 kPa0.01450377 psi
1 kPa0.1450377 psi
10 kPa1.450377 psi
50 kPa7.251885 psi
100 kPa14.50377 psi
200 kPa29.00754 psi
500 kPa72.51885 psi
1000 kPa145.0377 psi
5000 kPa725.1885 psi
  • Engineering Applications: Convert pressures used in HVAC, fluid dynamics, and mechanical systems.
  • Instrumentation: Gauge readings that need conversion between metric and imperial units.
