Control System Basics Quiz for Process Industries: 25 Advanced MCQs for PLC, DCS, SCADA and Feedback Control
This quiz helps process control engineers, instrumentation engineers, automation engineers, maintenance engineers, and technician level learners strengthen control system basics used in process industries. It focuses on open loop control, closed loop control, feedback control, feedforward control, cascade control, ratio control, split range control, selective control, supervisory control, PLC, DCS, SCADA, BPCS, sensors, transmitters, controllers, actuators, final control elements, setpoint, process variable, manipulated variable, and PID basics. Each question reflects practical plant logic, troubleshooting, and interview style learning. The goal is to improve technical understanding for oil and gas, chemical, power, water treatment, refinery, pharmaceutical, and food processing applications daily.
Start the Control System Quiz for Process Control, PLC, DCS, and SCADA Learning
Start this quiz to check how well you understand process control, control loops, and instrumentation in real plant applications. The questions cover control system fundamentals, PID basics, PLC, DCS, SCADA, and field devices used across process industries. Read each option carefully, choose the best answer, and learn from the explanation after every question in detail for practical learning now today.
 Why is supervisory control used above local control loops in many plants?
In a safety critical compressor package, what is the main role of a PLC based sequence control system?
Which control strategy is most useful when a large disturbance can be measured before it affects the process?
In a furnace fuel air control application, why is ratio control important?
A level control loop in a storage tank is oscillating after a valve repair. What is the most likely field related issue?
Which PID action predicts the trend of error and is often sensitive to noise?
Which PID action removes steady state offset?
Which PID action mainly reacts to the present error?
Why can excessive controller gain cause problems in a control loop?
What is the best example of a final control element?
In a standard feedback loop, what is the correct signal path?
What is BPCS in process industries?
SCADA is most suitable when:
Which system is generally used for continuous process monitoring, operator graphics, and centralized control in large plants?
Which system is most commonly used for high speed logic, interlocking, and discrete control in a plant?
Why is selective control used in some critical process units?
Split range control is best described as:
A ratio control system is commonly used when:
In a cascade control system, what does the primary controller usually send to the secondary controller?
What is the main advantage of feedforward control?
Why is feedback control widely used in process industries?
What is the manipulated variable in a flow control loop using a control valve?
Which device most directly measures the process variable in a control loop?
In a closed loop control system, what is the main purpose of the controller?
Which statement best describes an open loop control system in a process plant?
The average score is 72%
#ControlSystem #ProcessControl #ControlLoop #Instrumentation #Automation #PLC #DCS #SCADA #PIDControl #FeedbackControl #FeedforwardControl #CascadeControl #RatioControl #SplitRangeControl #IndustrialAutomation #ProcessIndustries #ControlEngineering #InstrumentationEngineering #AutomationEngineering #ProcessControlQuiz #ControlSystemQuiz #EngineeringQuiz #IndustrialControlSystems #ControlValve #ProcessEngineering
