Engineering Units to PLC Raw Counts Conversion Calculator
An Engineering Units to Raw Counts Calculator is a useful tool that allows the conversion of the physical measurements made using the engineering units such as temperature, pressure, or flow rate into figures that are in raw count form that PLC or any other digital control system can process. Such raw counts are expressed in … Continue reading Engineering Units to PLC Raw Counts Conversion Calculator
