DP calculator for Closed tank level measurement – Wet Leg system – Transmitter installed in zero based direct mount application
The phrase “wet leg” refers to a system where the transmitter low pressure side impulse line is completely filled with liquid (typically the same liquid as the process). A tiny catch tank is located at the head of the low pressure impulse line. The petrol phase or vapors will condense in the catch tank and … Continue reading DP calculator for Closed tank level measurement – Wet Leg system – Transmitter installed in zero based direct mount application
