Cv to Kv Conversion Calculator (Control Valve Flow Coefficient Formula + Example)
Cv to Kv Conversion Calculator The Cv to Kv conversion calculator helps engineers quickly convert control valve flow coefficients between imperial (Cv) and metric (Kv) units.  In control valve sizing, flow coefficient plays a critical role in determining how much fluid passes through a valve for a given pressure drop. While Cv is widely used … Continue reading Cv to Kv Conversion Calculator (Control Valve Flow Coefficient Formula + Example)
