Common Causes of Programmable Logic Controller(PLC) Failure and Mitigation Strategies
Factor No.1: Module Failure Factor No.2: Power Supply Issues Voltage Fluctuations Power Surges Complete Outages Harmonics and Electrical Noise Factor No.3: Ground Integrity The following are some significant uses of ground integrity: Safety: Protection against electrical noise: Equipment protection: To maintain ground integrity, engineers should perform regular inspections of the ground wiring and connections. This … Continue reading Common Causes of Programmable Logic Controller(PLC) Failure and Mitigation Strategies
