What is a Spool Valve? Configuration, Construction & application
What is the spool valve? Various configurations of Spool valves Construction of Spool Valve Closed Centre Open Centre Tandem Centre Float Centre Typical working of a spool valve Spool: Valve Body: Ports: Control Mechanism: Actuation: Function: Application of Spool valve: Hydraulic Systems: Spool valves are commonly used in Industrial, & mobile hydraulic machinery, & in … Continue reading What is a Spool Valve? Configuration, Construction & application
