Understanding Wet Contacts in PLC Wiring
Wet Contact Configurations Wet contacts are typically wired using a two-wire configuration, where one wire is connected to the PLC’s input or output terminal, and the other wire is connected to the common or ground terminal. The field device is then connected in series between these two wires. There are two main configurations for wet … Continue reading Understanding Wet Contacts in PLC Wiring
