Understanding Complementary Split Range Control (CSRC)
What is Complementary Split Range Control (CSRC)? Example Scenario: Temperature Control in a Chemical Reactor Components of the Control System The control system consists of the following components: Process System Temperature Sensing Element Temperature Transmitter Single Controller (PLC or DCS) Current-to-Pressure (I/P) Converter Control Valves Control Inputs Control Strategy CSRC Implementation Complementary Regions Safety Measures … Continue reading Understanding Complementary Split Range Control (CSRC)
