Loop Check vs Functional Test in Instrumentation Commissioning
Loop Check and Functional Test are the two most important processes that people talk about when a new process plant, skid, or automation system is being set up. Both are really important. Both are required for commissioning.But if you mix things together, you can miss problems, start up in a dangerous way, and have to … Continue reading Loop Check vs Functional Test in Instrumentation Commissioning
