EXtended high and low limit calculator
What is Lower Range Value (LRV) of a transmitter? Lower range value is the smallest measurement that a device can calibrated to measure. Another name for the LRV is Zero. What is Upper Range Value (URV) of a transmitter? Upper range value is the maximum measurement that a device can be calibrated to measure. Another … Continue reading EXtended high and low limit calculator
