DP calculator for Interface level measurement – Transmitter installed with Varying Tank Level and two Bubble Tubes
A differential pressure (DP) transmitter can be used to measure the interface level in a tank with two bubble tubes. The transmitter measures the difference in pressure between the liquid levels in each of the bubble tubes, which is proportional to the interface level.  To calculate the interface level using the DP transmitter, several factors … Continue reading DP calculator for Interface level measurement – Transmitter installed with Varying Tank Level and two Bubble Tubes
