How to Measure Density using DP Transmitter? A DP (Differential Pressure) calculator is used to measure the density of fluids by calculating the difference in pressure between two points in the fluid. When a constant tank level and a single bubble tube are used with a DP calculator, it can accurately measure the density of … Continue reading DP calculator for Density measurement – transmitter installed With Constant Tank Level and single Bubble Tube
