Control Valve Kv to Cv Conversion Calculator
Control Valve Kv to Cv Conversion Calculator The below calculator is used to calculate the flow capacity values from Kv to Cv for control valve applications. Control Valve KV and CV Definitions: Formula Used in this Calculator Cv=1.156×Kv Example Calculation Let’s demonstrate the usage of this calculator with an example: Given a Kv value of … Continue reading Control Valve Kv to Cv Conversion Calculator
