Control Valve Calibration Procedures
What is a Control Valve? Control valves are devices that regulate the flow of fluid. In a PLC (or) DCS system, control valves receive command signals from PID controllers. The valve positioners change the instrument airflow to the valve actuator based on the signal received from the PLC (or) DCS systems. This enables for the control … Continue reading Control Valve Calibration Procedures
