Cold and Hot Loop Checking in Automation: Key Differences and Step-by-Step Procedures
Loop validation is among the most important steps before launch in any industrial automation project. It guarantees that every component of a control loop is wired properly, signals are valid, and the loop acts as intended. Typically, this procedure is split into two primary phases: Cold Loop Checking and Hot Loop Checking. Both are absolutely … Continue reading Cold and Hot Loop Checking in Automation: Key Differences and Step-by-Step Procedures
