What is RJ45 Cable & How to make RJ45 Cable
- LAN Cable
- What is RJ45 Cable?
- What does RJ45 Stands for?
- Twisted Pair of Cable
- RJ 45 Connector
- RJ-45 connectors Types
- RJ 45 Cable Wiring Standard.
- RJ45 Color-Code Standards
- What are the materials needed in creating network cable?
- Steps in making RJ 45 Cable
- Step 1 – Purchase the required cable and RJ-45 connectors.
- Step 2 – Cut off the outer skin
- Step 3 – Reveal the Core
- Step 4 – Removal of Core
- Step 5 – Straighten the twisted wire
- Step 6 – Aligning of wire
- Step 7 – Sizing of Wire
- Step 8 – Plug wire into the Connector
- Step 9 – Crimp the connector to the cable
- Step 10 – RJ 45 Cable
- Step 11 – Testing RJ45 Cable
- Name RJ connector available
- RJ Connectors types
- Differences between RJ45 Connector and RJ11 Connector
- Why RJ45 is used?
- Is RJ45 faster than Wi-Fi?
- List some uses of RJ 45
- List few network topologies
- When a straight-through cable is used?
- When a cross over cable is used?
LAN Cable
What is RJ45 Cable?
RJ 45 cable is used for connect computer to Local Area Network (LAN) for sharing the information between the computers, communicating with printers, accessing of internet. This cable is used to transmit the information over a particular length. The cable run needs a connection termination, which calls for a jack to plug through an RJ45 port. RJ45 cables have a tiny plastic plug on either end, which is put into an Ethernet device’s RJ45 port.
The term RJ45 stands for Registered Jack.”45″ is the interface standard’s number.
A standardized telecommunication network interface for connecting voice and data equipment to a service provided by a local exchange carrier or long-distance carrier These are used in telephone and data jack wiring registered with Federal Communications Commission. RJ-45 is an 8-position, 8-conductor connector used in 10BaseT and 100BaseT Ethernet wiring, while RJ-11 is a 6-position, 4-conductor jack used in telephone cable.
Two wires of a single circuit are twisted together in this style of wiring in order to increase electromagnetic compatibility.
RJ 45 Connector
In Ethernet-based local area networks, an 8-position, 8-contact (8P8C) modular plug and jack known as an RJ45 connector is utilised (LAN). Eight pins are located on the port of an RJ45 cable plug, which is typically constructed of plastic. Four pins are used data transmission and reception. The rest four pins are for different technologies or to power networking
The RJ-45 was modified to fulfil the requirement for a different size connector brought about by the major technological advancements. RJ-45 connectors come in two sizes nowadays, one for Cat 5 cable and the other for Cat 6 cable. The user must ensure that they have the appropriate one for their task. Comparing them side by side is the most straightforward approach to tell them difference. Compared to the Cat 5 connector, the Cat 6 connector is bigger.
RJ-45 conductor data cable has 4 pairs of wires with a solid wire and a strip of the same color. Orange, green, blue, and brown wire pairs. 10BaseT/100BaseT Ethernet uses orange and green. The other two colors can create a second Ethernet or phone line (blue and brown). RJ-45 wiring uses T-568A/B.
T568-A T568-B
The two wiring standards are used to create a cross-over or a straight-through cable.
Straight Through Cable
Straight through cable is built using either T568 A or 568 B on both ends of cable.
These type cable is used when connecting data terminating equipment (DTE) to Data Communicating Equipment (DCE)such as computers and routers to modem (gateways) or hubs (Ethernet Switches)
Cross-over Cable
Cross-over cable is designed by connecting T-568 A on one end and T-568 B on other end of cable.These type cable is used when connecting DTE to DTE or DCE to DCE equipment.
As name
DTE – terminates the signals
DCE – Communicates the signal doesn’t terminate
The plugs on RJ45 cables have eight conductors with eight pins that are color-coded. Four pairs of eight wires, one for each positive and negative polarity, are utilized. The pin and color scheme used in conventional and standard wire are described in the table below
Pin No | T 568 A | T 568 B | ||
Color | Pin Name | Color | Pin Name | |
1 | Green Stripe | Rx+ | Orange Stripe | Tx+ |
2 | Green | Rx- | Orange | Tx- |
3 | Orange Stripe | Tx+ | Green Stripe | Rx+ |
4 | Blue | Not Used | Blue | Not Used |
5 | Blue Stripe | Not Used | Blue Stripe | Not Used |
6 | Orange | Tx- | Green | Rx- |
7 | Brown Stripe | Not Used | Brown Stripe | Not Used |
8 | Brown | Not Used | Brown | Not Used |
1. Unshielded twisted pair cable
The cabling system has one or more pairs of twisted insulated copper wires in a single sheath. It is the most common cabling system in data and telecommunications.
2. Wire Stripper
A lightweight, portable instrument that is used by professionals, often electricians, to remove an electric wire’s protective covering before replacing or repairing the wire.
3. RJ 45- Registered jack
4. Crimping Tool
A tool for joining two pieces of metal together by deforming one or both of them so that they hold each other. A crimp is the name given to the tool’s finished product.
5. LAN Cable Tester
Signal cable or other wired assembly electrical connections are checked using an electronic instrument called a LAN cable tester.
Since Ethernet cable is typically offered on loops of various lengths, you might have to calculate and cut the precise amount.
To remove the outer jacket, use your cable strippers 1-2 inches from the cable’s end.
Make a shallow cut in the skin with a utility knife to remove 1 to 2 inches (2.5 to 5.1 cm) of the outer skin off the end of the cable wire.
The jacket should just slide off the cable when you run the knife around it. There will be 4 exposed pairs of twisted wires, each of which will be a different color or combination of colors.
To reveal the cable core, fold the ends of each pair of wires backward.
Remove the core and throw it away.
Use two pairs of tweezers to straighten the twisted wires. With one pair of tweezers, grasp the wire at the curve, and with the other pair, gently straighten the bent.
Place the untwisted wires in a row in the direction they will enter the RJ-45 connector, moving from right to left.
To get the untwisted wires to the right length, hold the RJ-45 plug up against the cables.
The RJ-45 plug’s bottom should be flush with the cable’s insulation. It’s important to cut the cables so they’re flush with the top of the RJ-45 plug.
Take your time when trimming the wires and keep checking for a snug fit. Cut the untwisted wires a few times rather than having to start over because you chopped off too much.
Make sure the wires are aligned and inserted into the RJ-45 connector’s separate channels according to their colors.
Make ensure that each wire is threaded all the way to the very top of the RJ-45 connector. If you don’t make these checks, you will discover that your freshly crimped RJ-45 connector is unusable, and you will have wasted your time.
Using the crimping tool, force the jacket and cable into the RJ-45 connection so that the wedge at the bottom of the connector is driven into the jacket to crimp the connector to the cable.
To make sure the connection is correct, recrimp the cable.
Crimping an RJ-45 connection onto the other end of the cable can be done by following the methods given above.
Test the RJ45 cable with LAN tester to make sure the crimping has been done properly .
- RJ11 Connector
- RJ11-W Connector
- RJ14 Connector
- RJ21 Connector
- RJ25 Connector
- RJ45 Connector
- RJ48 Connector
- RJ61 Connector
RJ Connectors types
1. RJ11 Connector
Registered Jack11 is a four- or six-wire telephone-type connection for wall plates.However, most older wired telephone lines link to ISPs via four-wire twisted-pair connections (Internet Service providers).
2. RJ11-W Connector
The RJ11- modular connector is standard form. It bridges telephone lines and provide wall mount functions
3. RJ14 Connector
The 6P4C modular connector is standard form.It is identical to an RJ11 connector but uses two telephone cable lines and can be used as a modem port in a computer.
4. RJ21 Connector
It supports 25 telephone lines with 50 conductors. It is mainly operated in large network. It operates many switches and devices in networks.
5. RJ25 Connector
This connector is a standard connectors use modular connectors with six locations and six connections (6P6C). Modular plugs connect three telephone wire lines.
6. RJ45 Connector
Ethernet connections and network equipment use registered jack connectors. It facilitates local area network data sharing like a phone jack. Ethernet wires, RJ45, are wider than telephone jacks, RJ11, 14, 21, and 25. It links STP and UTP cabling in the Ethernet star topology. RJ45 connections connect computer and telephone lines, wall plates, patch panels, and other networking devices using 8P8C modular connectors with distinct twisted pairs.
7. RJ 48 Connector
RJ48 is 8pin modular jacks & twisted wire cables for data transmission. Its pin out is different from RJ45 connector.
RJ48-S wall mount digital lines use 56 kbps.
8. RJ61 Connector
It uses an 8P8C connector to link network equipment’s twisted-pair cables, unlike RJ11.
Parameters | RJ45 | RJ11 |
Design | RJ45 is designed with 8p8c connections (8 positions & 8 Contacts) | RJ11 is designed with 8p8c connections (8 positions & 8 Contacts) |
Bandwidth, Shape & Size | Transmitting of data’s speed rates up to 10Gps via Ethernet connection. RJ45 is rectangular shaped. The cable wire is large in diameter | Transmitting of data’s speed rates up to 24Mps via Ethernet connection. RJ 11 is compact & square shaped. The cable wire is smaller in diameter. |
Wires | Eight wires are linked together | Four wires are linked together |
Application | It is used with Ethernet cables & telephone lines. Also used in Computer networking line | It is used in telephone cable lines in single double or triple standard. Voice Application, ADSL lines & Modem cables. |
Why RJ45 is used?
The RJ45 connector, is a standard for connecting computers to LANs (LAN). This type of connector was initially developed for use with telephones but has now found widespread use beyond the realm of telephone talks.
Ethernet connections are more secure and reliable than wireless networks like (WiFi) and they also tend to be faster. Also RJ45 has high reliability &good security.
- Telephone and network cables typically have RJ-45 connections.
- One common application is in serial network connections.
- Computing devices with an active Internet connection
- Local Area Network
- Wide Area Network
- Linking a router to a hub
- Linking a computer to a switch
- Linking a local area network (LAN) port to a router, hub, or computer are all possible.
- Linking two similar networking devices, such as a hub and another hub.
- Connecting two computers together; linking two switches together.
