Instrumentation Questions
Proximity Switch MCQ-2
In this article, we’ll provide proximity switch questions and answers, as well as details on setup, troubleshooting, and general usage. If you are an engineer, a technician, or just someone who is curious about this technology, the questions and answers that are included in this area will provide you with useful information on proximity switches and the applications in which they are used.
1 / 24
Which of the following is an example of a factor that has the potential to influence the accuracy of a capacitive proximity switch?
2 / 24
Why does a proximity switch need a magnetic field test?
3 / 24
What should you do if a proximity switch reports erroneous reading?
4 / 24
How should a damaged proximity switch be handled?
5 / 24
What should you do if a proximity switch fails to detect objects?
6 / 24
What should you do if a proximity switch produces false readings?
7 / 24
What are some typical installation issues for inductive proximity sensors?
8 / 24
How can a proximity sensor’s sensitivity be evaluated?
9 / 24
What does a “blind zone” mean when installing proximity sensors?
10 / 24
How can electrical interference be minimized while installing proximity switches?
11 / 24
What kind of issue do ultrasonic proximity sensors frequently have?
12 / 24
What are some typical installation issues with photoelectric proximity switches?
13 / 24
How to modify a proximity switch’s sensing range?
14 / 24
What is a typical issue with inductive proximity switches?
15 / 24
What factor needs to be taken into account when installing a proximity switch?
16 / 24
Which of the following variables can impact a proximity switch’s accuracy?
17 / 24
What is the standard inductive proximity switch’s maximum sensing distance?
18 / 24
Which proximity switch is used in industrial automation the most frequently?
19 / 24
What distinguishes a normally closed proximity switch from a normally open one?
20 / 24
How does a capacitive proximity switch find an object?
21 / 24
What is the function of a proximity switch?
22 / 24
Which of the following describes a use for an ultrasonic proximity switch?
23 / 24
Which of the following is a capacitive proximity switch application?
24 / 24
Which of the following is a drawback of employing a capacitive proximity switch?
The average score is 43%
Exit
Keep in mind that the objective of this series of questions and answers is to provide information on proximity switches and the applications that use them.
 Always refer to the documentation and instructions provided by the manufacturer whenever you need specific information regarding a particular model or use of a proximity switch.
When it comes to non-contact object detection, proximity switches are helpful instruments, and the type of proximity switch that should be used is determined by the requirements of the application.
Always refer to the documentation and recommendations provided by the manufacturer when choosing proximity switches, installing them, or troubleshooting issues with them in relation to your particular use case.
Refer the below link for Proximity switch MCQ-1 Quiz
Proximity Switch – MCQ1
For more quiz refer Explore Instrumentation and Control: Engage with Our Interactive Learning Quiz!
Sundareswaran Iyalunaidu
Related Articles
Back to top button
