Mounting the level transmitter exactly at the tank’s base level is not always practicable. In some instances, it may not be viable to install the level transmitter. Let’s say that in order to make it easier to maintain the level transmitter, it needs to be positioned Length (h1) below the bottom of the vessel. At … Continue reading Closed tank level measurement – Wet Leg System – Transmitter installed in non-zero based remote mount application
