4-20mA to PV scaling calculator
A physical process value, such as a temperature, pressure, liquid level, or other physical quantity, is transferred via 4-20 mA signals. The corresponding physical process value is represented by the mA current in the loop. Example: A 200 degree temperature is measured via a 4-20 mA temperature transmitter with a 0 to 1000 degree Celsius … Continue reading 4-20mA to PV scaling calculator
